String to Upper Schedule Field
andrew8QEC8
andrew8QEC8
I am trying to modify a dynamo script to make schedule field names string to upper, I used another string to upper that worked with elements. But I am not sure how I could get this to work for that text that is inside of a schedule. Fairly new to dynamo but I have used Unreal Engine and Grasshopper. I think I need to figure out what the element category of the text for schedule field is..... any help is much obliged.SRA Update Field Title Upper Case_2022-09-08_04-12-28 CODE FAIL.png
Here is an example to change Comments Field of all Elements under Structural Framing category from lowercase to UPPERCASE.
Set Categories and String nodes to Is Input and you can run the script using Dynamo Player with dynamic input to choose from different categories and parameters.
andrew8QEC8
That pretty much does it, the only question is does the list.Combinator allow me to put multiple lines of string as input for the "Parameter name" Right now I would work around it by having multiple lines of string for "Comments," "Width," ect. and plug in them in and out.
