how can I check if a slab has an opening in Revit and Dynamo?
firas007noori
Message 1 of 13
firas007noori
If I have a slab or a floor in Revit and I wanted to use Dynamo to check if it has any openings in it??
Any ideas of how I can do that?
Thanks in advance
Firas Noori
Replies (12)
Message 2 of 13
Me think you can try to compare the area of the outer footprint versus the actual slab area.
Message 3 of 13
firas007noori
thanks, I thought of that too but how you can do that in Dynamo?
Firas Noori
Message 4 of 13
I have no idea.  That will need a Dynamo expert.  Sorry.
Message 6 of 13
firas007noori
many thanks, but the case of the pipes are already designed and Dynamo can actually find their locations, but how you can define if an object or a slab has a hole in it?? in this case, you Dynamo to analyze the object for you to find where the hole is?
Firas Noori
Message 7 of 13
This was the page I was looking for originally...  https://dynamonodes.com/category/standard-nodes/revit/
But basically it sounds like you are looking for an interference check... https://forum.dynamobim.com/t/clash-detection-using-dynamo-revit/11332/5
Message 8 of 13
firas007noori
I do appreciate your help dear, but it is exactly the opposite of what I want, in the pipe example, the location of the pipe can be found and so you can open a hole in a slab for it, for me, I have a slab in Revit and I want to detect if it has a hold in it or no??
Many Many thanks in advance
Firas Noori
Message 9 of 13
Maybe a Priest could help you determine whether or not the slab is holy.
Get it? "Holes" ... "Holy".
ugh.
Message 10 of 13
That is an interference check between pipes and the floor...if there is a collision (no holes) then it will report that...if there isn't a collision (Has holes) then there are no issues.
Message 11 of 13
firas007noori
I do thank you again, but there are no pipes in the case I am working on, it is an architectural check for any possible loaded floor, so if you have any idea of how to check the existence of a vertical opening in a slab, that would be really appreciated.
Firas Noori
Message 12 of 13
I think the steps are like:
- edit the floor boundary, copy the outer loop, close
- paste to make a filled region or another floor, get the new area, delete
- compare new area to original: if equal = no holes, if more = holes
- write the results to a parameter of the floors
How to put it together in Dynamo?  I have no idea whatsoever.  You are better off asking the question over at the DynamoBIM forum.
Message 13 of 13
firas007noori
Many Thanks
Firas Noori
