Horizontal Shape Handles on Windows
Hello Autodesk-Community,
is it possible to get horizontal shape handles on windows?
I created a generic window family and set the parameter width and height to instance. I only have the shape handle for the horizontal dimension in my project.
I am working on this family for fast, exact and instance-based as-built-modelling.
Thank you 🙂
Ilic.Andrej
For the reference planes that make the handles, verify that the "Is Reference" value is any other than "Not a Reference".
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
The value is "weak reference".
I have a similar Problems with doors. There i only have horizontal shape handles and no vertikal shape handles. Is is a "catagory issue"?
Ilic.Andrej
I rly don't know what could be the cause of this. Read this thread:
http://revitelemental.blogspot.rs/2010/06/shape-handles-dragging-grips-and.html
Try that....
Andrej Ilić
MSc Arch
Sahay_R
This is what you need to see in the family -
to see this in the project
All else failing, can you share the problematic family?
Rina Sahay
Revit Architecture Certified Professional
Thanks for your help!
The Problem was the view. You only can Change dimensions with shape handles, when your view is parallel to these axis. My wall wasn´t in a 90° angle, so i only was able to Change the vertikal.
Kind regards!
