Home button
Home button
arkitek2ss
Message 1 of 12
Home button
arkitek2ss
With 2019, the Revit Home only shows the central model.  how come it doesnt show the local models instead?
Replies (11)
Message 2 of 12
Because you are supposed to open a new local each time you open the project...not the local file again.
Message 3 of 12
Avaris.
Opening the old local file means you are essentially working in an old file which is not synchronized yet. In extreme cases this can lead to crashes. Therefore opening a new local file is better. Paul F. Aubin explains in his Lynda tutorials he always makes a new local file with a timestamp, that way you essentially have also local backups.
Message 4 of 12
arkitek2ss
strange.  I (and I assume a lot of others) have always opened the local file to work on the project.  But since there is a local (shared project) there is already a backup folder.  so every time one opens the central and creates a new local, there will be extra folders as backups with the timestamps?
so then all your local files are in a single folder.  I have it so that each local file is in its projectname folder with the file and backup folder/files
Message 5 of 12
No need for timestamps if the central model already has backups...
Message 6 of 12
arkitek2ss
OK.  I understand the process now.  will need to abandon the 'all local files to have their own project folder' and then keep all local files in a single/base folder.
these helped me as well:
https://help.autodesk.com/view/RVT/2019/ENU/?caas=caas/sfdcarticles/sfdcarticles/Unexpected-generati... this article then points to:
https://bimchapters.blogspot.com/2018/08/revit-20191-new-home-screen.html
Message 7 of 12
arkitek2ss
another question - what does it take to get a project to show up on the Home/Recent Files?  I have 3 central models and 3 standalone projects along with 3 Sample Projects?
I have opened a few projects already that are standalone but they are not showing up.
thanks again!
Message 8 of 12
Corsten.Au
recent files..recent files..
have some naming convention for Central files and standalone files..
Example
Central file can be ....PROJECT1_CF_2016  ( central file, 2016 version )
Standalone Project2_V16 ( Standalone, Version 2016)
You can add a shortcut in revit for folders used frequently..
that can be project folders, or even Documents folder where local files are created...
add shortcutsadd shortcuts
Corsten
Building Designer
Message 9 of 12
arkitek2ss
Thank you @Anonymous.  already have that setting turned on and the shortcuts.  just wondering why projects/models are not showing up.
is there a way to clear projects/models from Recent Files?
Message 10 of 12
arkitek2ss
thank you.  just found a thread to reset the recent files list in the revit.ini file.
Message 11 of 12
RobDraw
Great! Care to share so that others can benefit?
Rob
