HO do i get my stairs to go up the my first floor?
svalente9GJKH
svalente9GJKH
Id set my stairs to go to first floor. The result is it sets the riser just short.
my first floor is the subfloor, i need the rise to  go up so that the tread will be flush with the finish floor.
When I try to modify the stair to be first floor +1"  it sets the top of the stair like 6" below.
What is going on here,  do I need to redraw the stairs?
If you want to eliminate the top riser then Edit Stair > Select the Run > Untick End with Riser.
If you want to add a top tread aligning with the floor finish keep then edit the Stair in a plan view, click the Run, drag the Blue Dot at top and drag it toward the floor to add one more step.
svalente9GJKH
I want the top tread to align with my floor finish,  but I don't model my floor
finish, I want my top of first floor to be plywood,
 think Revit by default leaves an inch gap at the top of the riser for finish,  but I don't want it to do this.
to remedy this I am trying to make stair top level - first floor + 1" top offset,  but Revit doesn't like this and/or
it DROPS the height of the stair...
is there  a way to disallow that gap?
It should go to whatever elevation you set.  I can show you when I get to the computer.
