Message 1 of 11
Hello Autodesk Revit Community
Indeed, I read the following note in one of great books that cover Revit Architecture under section "Creating Views" :
If you had floors already placed in the model, Revit would create the interior elevation so that it extended only to this geometry. Because you don't have floors, Revit doesn't know where to stop. If you happen to place an elevation without floors and put them in later, Revit won't make the adjustment. You'll have to adjust the interior elevation manually for the new floors.
Therefore, I need a specialist in the Revit app to clarify the above note.
