I've check Object styles, Model categoreies, Element overrides, model display
Any ideas? - just want those lines not pink
Solved by barthbradley. Go to Solution.
Looks like you are in Sketch/Edit Mode of some command.
...Let's avoid the guessing game here. Just post your file and we'll take a look and see.
Graphic Overrides can be applied by Element, by Category and/or by Filter.
Probably looks like that as i have a bunch of halftoned items but no i'm not in a sketch mode.
I've isolated it down to the view range
If i have bottom of range above the range limit everything below bottom of range becomes these pink dashed lines
which i don't mind but i'd like for it to not be pink and not dashed. not sure where i could possibly control these graphic options.
if i move bottom of range to be the same as my range limit it's pink lines become what i've set my graphic view templates to be but there are certain section tags I would not like to see below a certain point. and on a large sheet thats lot of tags to individually hide....
