Hi could anyone help parameter problem? which cannot edit in the family edit mode
firstpin
firstpin
Hi
i copied family to use same parameters in other families
but there are those copied paremeters that are not show up in the family edit mode
,which i cannot edit or delete those parameters
please help
Edit Type to access Type parameters.
firstpin
i can not alter type . . in the project . . why not it show up some of parameters?
What do you mean? Click Edit Type button on the Properties panel in your 1st screenshot.
firstpin
can not delete any parameters label in the edit type . .
Sorry I thought you wanted to edit the value of the parameters.
Maybe they were added to Project parameters. Open project parameters and see if you can find them.
Wild guess: Maybe it's a Project Parameter and not a Family Parameter.  Honestly though, I don't understand your description of the problem or what it is you are trying to do but can't do.
...another wild guess: maybe you selected the wrong Family. Maybe the Family is comprised of Nested Shared Families.  Use TAB-Select to cycle to the Nested Shared Family.
