importing a cad file into revit
4 ANTWORTEN 4
Nachricht 1 von 5
stav1233
360 Aufrufe, 4 Antworten
Hey everyone I have a problem importing a cad file into revit.
The cad import is working fine when I import it to the first floor.
But when I am tring to lock over from the second floor I can not see the cad file.
Tried to play a bit with the view range and also tried to import the same cad file to the second level,Nothing seems to work.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: stav1233
I think you imported it in with the box Current view only box checked, meaning it is only visible in the view you imported it in.  Just copy paste aligned from one view to another.
Nachricht 3 von 5
ennujozlagam
you can try to copy and paste aligned to other floors (views)  the cad file and erase later? thanks
Nachricht 4 von 5
RSomppi
Wouldn't linking the file, instead of importing, be a better idea?
Nachricht 5 von 5
Is it within the View Range?  Does it show up as an Underlay?
