Revit 2022.1.1 ifc export crash to desktop
hve-architecten
Message 1 of 10
hve-architecten
I have a problem and thats when exporting to ifc from revit 2022.1.1 it crashes to desktop (revit).
Installed ifc exporter v22.4 but the same crash to desktop happens. Consistently.
With a project we are working with multiple firms and they also are experiencing the same export to ifc problems from revit 2022.1.1.
With revit 2022.0 according to some there are no problems....
This is a very big issue!!!!!!
Replies (9)
Message 2 of 10
hve-architecten
It looks like autodesk is deliberately avoiding answering this issue? Autodesk doesn't like ifc
Message 3 of 10
hve-architecten
I am sorry for the blame that i put on autodesk for the ifc export functionality. It appears to be the latest enscape version  which prohibits to create an ifc export in revit 2022.1.1......
So i will contact Enscape....
Message 4 of 10
AndyL_Work
Firstly it's a little unfair to say Autodesk don't like IFC they have been on board with it from the beginning and were one of the first software houses to add it to the software export and import process.
Back to the problem...
I have had a similar problem on a customer site, this may resolve the problem so this may be worth a try.
  • Close Revit
  • Go to your add-ins folders and copy them
    • C:\ProgramData\Autodesk\Revit\Addins\2022
    • C:\Users\%USERNAME%\AppData\Roaming\Autodesk\Revit\Addins\2022
  • Start your Revit try an IFC export.
  • if it works - shut Revit.
    • move an/some add-ins back to the original folder.
Repeat until all the add-in(s) are back or you find the one that causes the problem.
In my case, this worked even with all the add-ins back in place and Revit is all ok.
Please accept the solution if it works for you,
Have a good one, Andy.
Message 5 of 10
MartijnKalec
It's still partly to blame on Autodesk, because they made it possible for Add-ins to crash other add-ins. And sure, I won't blame people for making a mistake. But I do when it's been 10 years, and they still didn't fix it.
I've already contacted Enscape a month ago, even gave them fully detailed debug information, and after a month they haven't even started to pick it up:
https://forum.enscape3d.com/index.php?thread/19746-revit-crasching-when-exporting-ifc/
I have a mailbox full of angry clients, because they blame my add-in for crashing Revit. And in the meanwhile Enscape doesn't even care, because why would they. They simply put your add-in under "Enscape is incompatible with add-in xxx". You know why? Because they're a big company and they can do whatever they want.
Message 6 of 10
hve-architecten
Meanwhile i got enscape and revit 2022 ifc working again.
Took some specific steps:
1. first i deinstalled enscape
2. then deinstalled revit ifc program
3. Installed ifc for revit 22.4
4. Checked if revit could export to ifc......yes!
5. Installed enscape 3.2 (latest) and still ifc functionality.
So there is still some programming to do between enscape and autodesk i guess..
Now i have a new pc and hope everything works out
Message 7 of 10
joe_keogh
We have recently been looking into this issue for one of our clients and, while it's a bit of a work around,  our awesome Design Tech Team have come up with a solution which may help those of you using AEC Collections or with access to Navisworks manage, until Enscape resolve the clash.
We opened the Revit file/s in Navisworks then used the Codemill IFC Exporter for Navisworks to export the IFC file.  Just be sure to remember to "Select all" in Navisworks before using the export tool.
Step 1: Install Navisworks Manage 2022 (if you haven’t already – part of your AEC licence)
Step 2: Download and install Codemill IFC Exporter for Navisworks
Step 3: Open Navisworks
Step 4: Append Revit Model
Step 5: Click on Select All Button – Model should turn Blue
Step 6: Navistools IFC Tab | IFC Exporter
Step 7: Schema Version IFC2X3
Step 8: Predefined Selections : Revit Category
Step 9: Export IFC (Select Folder and Name for File
Step 10: Check IFC Export in Open IFC Viewer
I hope this helps
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
Message 8 of 10
martin.taurer54TJX
1. Disable Enscape by moving it out of
  • C:\Users\%USERNAME%\AppData\Roaming\Autodesk\Revit\Addins\2022\
2. Do an IFC Export without Enscape enabled
3. Re-enable Enscape
4. Now for me both IFC Export and Enscape work again
Message 9 of 10
hve-architecten
Thanks, but already found that "solution" except then revit 2020 failed to create an ifc.
I then deinstalled and reinstalled enscape 3.1 and everything works fine. The problem is enscape 3.2 latest version..
Message 10 of 10
lauroschnittger
Observer
Observer
I can't believe that that actually worked... Thanks!
