Help with filter creation
James_lB2
James_lB2
Hi all, attempting to create a filter so I can remove the elevation markers for specific sheets but unable to get it to work.
Here is what I have thus far. What this does is just remove all elevation markers from a view rather than specific ones (sheets A410 and A411)
The version below works but just removes the marker, not the circle as well.
thanks in advance
syman2000
You may want to duplicate the elevation tag and called it another elevation type. When you hide, choose that elevation type to hide and it should hide in your elevation. Right now your filter set a condition where only arrow will be turned off. Regardless what you do with filter, it will never turn off the circle tag unless it is part of another elevation type.
As well if the elevation is at different scale, you can choose the elevation tag and hide at scales coarser than the scale. If your plan is 1:100 or 1/8" you can tell the tag to hide when it is 1:50 or 1/4" and any scale bigger will automatically hide those elevation tags.
If the above method don't work, then select the elevation hide by element in both of those sheets.
James_lB2
