Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Help!! Revit is not printing to scale
Message 1 of 26
Hi
CAN SOMEONE PLEASE HELP ME ASAP, ITS FOR A JOB!!!!
I have just download Revit 2018 and its not printing to scale. I've read all the forums about changing settings, changing the printer settings, printing to PDF to then print and nothing is working.
The weird part is some of my elevations are as they are dimensioned and others aren't. It's got to the point where now i need an expert to actually have my file and see whats wrong because nothing is working and im not getting paid for my job until its done!!
Replies (25)
Message 2 of 26
Perhaps, out-source the printing?
Message 3 of 26
Unforuntately that doesn't help me now, i'm not in a stage to out source the printing and it would defeat the purpose of them outsourcing to me!
Message 4 of 26
...well then, finish the job in the version you developed it in. Screw upgrading versions in the middle of a project - especially at the 11th hour!
Message 5 of 26
I didnt upgrade mid project its just not printing to scale ????
Message 6 of 26
The nice thing about Revit is that it is WYSIWYG. In other words, the issue is likely attributed to your printer settings, or "a loose nut behind the keyboard".
Message 7 of 26
Is there an expert that can help me? Your comments are not helping me in the slightest ......
Message 8 of 26
Boy, you're rude!
Message 9 of 26
Well this is supposed to be a forum to help people and you aren't helping and i'm under the pump?
Message 10 of 26
Stephanie: I understand your frustration and angst. No need to lash out.
You are seeking help to understand why you can't print to scale. The issue is not related to Revit. That's all I'm pointing out. It's a user error. plain and simple.  Get it?
What are you printing to? PDF? Let's examine the settings....ok?
Message 11 of 26
...unfortunately, "real-time" expert help has almost expired. You in or out, Stephanie?
Message 12 of 26
Corsten.Au
Just do one thing at a time..
First thing first..
Decide the Sheet size.. am Assuming A1 Sheet. ( can be A1, A2, A3, A4 )
Place a " Floor Plan " on a " sheet "
ex Floor Plan 1:100 scale
Sheet A1..
if that plan doesn't fit on that sheet, then change the scale of the plan,
ex : Floor Plan 1:200 scale..
see on which scale its fitting on the A1 sheet..
and once you figure that out. make all the drawings of that scale..
ex: All plans, elevation, section 1:200 scale...
hope that helps..
Cheers..
Corsten
Building Designer
Message 13 of 26
ennujozlagam
@Anonymous hello, you can refer to this link Best Practice: Printing In Revit. thanks
Message 14 of 26
Hi there
That was helpful thank you however all these settings are changed and its still not printing to scale?? Any ideas? I'm more than happy for someone to take my file and take themselves at the settings because I'm at a loss I've changed everything i can think of!
Message 15 of 26
ennujozlagam
@Anonymous hello, pm me and i will take a look and i will give my email add. thanks
Message 16 of 26
ennujozlagam
@Anonymous hello, anyways have you install latest updates Revit 2018.1 and Revit 2018.2 and see if helps. thanks
Message 17 of 26
ennujozlagam
@Anonymous hello, here we go, the problem is the crop view and crop region visible. i just open only one file and assuming the other one is the same issues. thanks
Message 18 of 26
So, Stephanie -- the lesson learned here is that this was not a PDF scaling issue after all! Sounds like the PDF was printing WYSIWYG all along. Hmm?...a "loose nut behind the keyboard" maybe?
Nice doing business with you.  Have a good day.
Message 19 of 26
georgehobel
is it just me, or did you intentionally leave out the audio?
George Hobel
Reflections of Charlotte
Residential Building and Design
Message 20 of 26
ennujozlagam
Hello, sorry, don't have audio my voice is not nice to hear. Thanks
