Having trouble painting Flange (Structural Beam)
Message 1 of 11
I've been able to paint the all of the beams/metal, but not this specific row. When I click the Modify -> Paint tool and hover over the beam, it doesn't highlight blue to paint it.
Any ideas?
Replies (10)
Message 2 of 11
I don't think you can paint any loadable families except architectural columns.
Message 3 of 11
Why don't do assign a Metal Material to it?
Or, apply Paint the surfaces of the beam in the Family with a Paint Parameter.  Know how?
https://wrw.is/how-to-assign-parameter-to-painted/
Message 4 of 11
@ToanDN I was able to paint the structural columns/beams by simply applying paint to the face.
@barthbradley thank you for suggesting those, but they didn't work. I realized the Structural Material under Materials and Finishes in the Properties tab was the standard grey, so I changed it to the desired paint and it worked!
Message 5 of 11
You cannot apply materials via the Paint Tool to faces of component family instances (except columns) in a project. You can apply the materials via the Paint Tool to faces of a component family in the Family Editor.
Message 6 of 11
You did not paint the beam, you just changed its structural material. Paint is a tool under Modify tab and it does not work on structural framing families. Period.
Message 8 of 11
Thanks @ToanDN , makes sense. Since the Paint tool worked on the Structural column, will it render differently than if I were to place a paint parameter to the family? The Structural Material is still standard, but it's showing the paint I applied.
I'm still learning, so any tips/tricks are appreciated!
Message 9 of 11
martijn_pater
Ofcourse I can't look on your screen, but it seems to me you did not apply a paint material  (not possible for structural beams in project environment) but you just associated a project material to the family material parameter... See below link and drill down, as @barthbradley likes to say... 🙂 If you did paint it, you did so in the family itself... or it's not a structural beam category family...
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Message 10 of 11
What was the solution?
Message 11 of 11
@barthbradley the solution would be the link @martijn_pater provided above ^, but also relates to what you and @ToanDN were mentioning about not being able to paint the structural elements.
