Use pick up line with an autocad imported file
Message 1 of 9
Hello guys, I tried to create a profile family using the  cross-section of the shape of a rail which I have in an autocad file (I have it in an pdf file also). My intention was to use the file as a template and use the "pick up line" tool of the family editor to create the profile and then using with a rail to model a railway. The problem is that it won't work, the command don't recognize or select any line, and I find the drawing line by line very hard, is there a way that I might accomplish what I need without drawing it line by line? Thanks everybody.
Replies (8)
Message 2 of 9
Is the AutoCAD Profile created with AutoCAD Linework?
Message 3 of 9
Hello! no, it isn't, I imported a pdf into autocad, then I  scaled it
Message 4 of 9
A PDF? No wonder you can't select lines. There is no lines to select. Just pixels. Revit doesn't do pixels.
Message 5 of 9
Export the PDF to DWG using illustrator or the like, then import that DWG in your revit family to trace/simplify.
Message 6 of 9
No... I imported the pdf to cad, then in cad I built the profile as a whole polyline, and then that file is the one that i exported to revit, I'm attaching the file so you can see.
Message 7 of 9
A spline? I don't think Revit can pick it. You need to draw it in AutoCAD as polyline or lines/arcs.
Message 8 of 9
Thanks,gonna try it
Message 9 of 9
Partially Explode.
Here's a Revit extrusion made from your DWG.
