scheduling an instance parameter that's within a title block?
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
christopher.YR
1168 Aufrufe, 3 Antworten
I am trying to toggle the visibility of an element within our title block from within a schedule in our project. If I understand the logic of Revit this cannot be done but want to make sure there isn't a Dynamo script or something else I may be missing. In the TB I have created a yes/no instance parameter from a shared parameter and assigned the visibility of the element to this new parameter. After loading the title block I then create a project parameter from the same shared parameter and assigned this to sheets. When in the sheet view the tick boxes don't activate the elements visibility, only when I select the title block is when these tick boxes work.  I have done similar moves with labels linked to parameters and was able to schedule these in a sheet list schedule.  Tia
3 ANTWORTEN 3
Nachricht 2 von 4
Mark.Ackerley
als Antwort auf: christopher.YR
Hey,
Agreed, there is a separation between the sheet and the titleblock family, I don't believe a sheet schedule will be able to update the titleblock family.  I also don't believe you can schedule titleblock families.  For a Dynamo graph, this would be quite simple, here is an example of how you might use it...
Hope that helpls,
Mark
Nachricht 3 von 4
What element you want to toggle? If it is a label then it can be done natively.
Nachricht 4 von 4
christopher.YR
als Antwort auf: Mark.Ackerley
@Mark.Ackerley , that is what I suspected given the logic. This t/f boolean looks like a great workaround, thanks!
@ToanDN , Yeah I have done this with labels but this was a import symbol element that some projects use on certain sheets. Unfortunately our TB family types are chockablock with custom grids etc. So I didn't want to add more.
