Hardware Recommendations for Revit 2019
Message 1 of 25
the age old question, what is a recommendation for a "biggest bang of the money" computer? In the past there have been posts that have made good recommendations, but nothing is current that I've found. Looking to spend $1500 to $2,500 without monitors. All of my office computers use dual monitors, 500 MB SSD (Samsung Evo 850) and a 1 TB HD (WD black). I'm partial to ASUS and SuperMicro motherboards, Intel CPU's. I have 2x8 PC4-22400 DDR4-2800 Ripjaws memory unused in my desk and may add more if necessary. Graphics cards are still a big question, we have used gaming cards in the past but recently used Radeon Pro WX1500 8 GB (probably over kill here). I am interested in reliability and service life and not interested in over clocking and liquid coolers.
We're currently using Revit BDSP 2018 but have 2019 on the shelf. Mostly high end custom homes, file size <100MB, some rendering. What would you recommend?
Title renamed for clarity by @Viveka_CD for user request on hardware requirements
Accepted solutions (3)
Replies (24)
Message 21 of 25
Viveka_CD
Hi @Anonymous
You marked my previous post as the solution, I've unmarked it as this was a follow-up, not the solution.
Please mark relevant posts that helped you with 'accept as solution' to help others seeking similar solutions.
Thanks!
Message 22 of 25
I went through what you are going through now last august.
I have the i9-7900x just came down in price work great. needs alot of cooling. I have 8 fans and water cooling
10 cores running at 4ghz (overclocked)
my motherboard Asus prime x299-a work great and two slots for ssd's
I have a nvidia p4000 8g
the amd wx7100 is almost the same thing and less expensive certified by autodesk also check the WX5100
I have a starter water cooling kit and it work just fine
64 gb corsiar ram
my case cooler master mastercast 5 pro.
Message 23 of 25
Isn't there an updated version for 2019?!?
Altough there is a small section on CPU, it is absent on hyper-threading. The RFO benchmarks appear to indicate no benefit in having hyperthreading.
This is important whne choosing from an i7-9700K or i9-9900K.
Any recommendation on this is highly appreciatted.
Message 24 of 25
What about laptops, any recommendation?
Message 25 of 25
Hi really big question call me we can talk about your needs 2019612670
