Guide Grid in REVIT
Guide Grid in REVIT
Guide Grid in REVIT
Hi!
I have a question about guide grid in Revit. How I can create grid lines like the picture which I attached below and to clarify my question can you look over this video https://www.youtube.com/watch?v=PhS7yIvVyQI
ennujozlagam
hi, i don't know if i answered you correctly. Pleasse see attached.
or check here : http://www.augi.com/library/revit-a-neater-alternative-to-the-guide-grid
hope it helps. thanks
chrisplyler
I'm pretty sure a guide grid is wanted in views, not in sheets. The vid shows working in a view with a grid at the first level. I'm not watching that whole thing, by the way.
I would suggest making a suitable grid in Autocad, then linking it in to your project. Or just array a bunch of reference lines.
L.Maas
In sheets you can use guide grids. In views you can use Show Workplane.
Objects will snap to the lines of the workplane grid.
You can set the dimensions of the grid.
Note that his is a representation of the workplane. This means that it will show the present representation of the active workplane. So you have to make sure that it is properly set.
Louis
Please mention Revit version, especially when uploading Revit files.
