groove in floor
groove in floor
NERDASORUS
Message 1 of 28
groove in floor
NERDASORUS
hello
what is the best way to create a groove on a floor with elevations like this one:
i need to create a groove from the 5000 point to 3000 point, the groove would look like this:
really appreciate your help
Replies (27)
Message 21 of 28
Message 22 of 28
NERDASORUS
what happens when the floor doesnt join the wall??
Message 23 of 28
Make the wall longer.
Message 24 of 28
NERDASORUS
I made it -7000 below and 7000 above and still not cutting!
the wall joins every other slab for some reason, i have attached the model in my previous reply.
Message 25 of 28
I mean longer, not higher.
Message 26 of 28
NERDASORUS
 this is the slab that is not joining, i don't see why extending the wall would solve it..
but I have tried it and still nothing
Message 27 of 28
I see your file now.
You can attach the wall base to the floors, click OK when you see the warning about Opening Cut.
And you will need to fix an elevation change between the two floors in order to create the void sweep.
Message 28 of 28
NERDASORUS
you are a life saver, thank you! that actually helped me solve another separate problem.
back to the problem at hand (and so sorry to be dragging this for too long), following your solution i can pick the whole path without a problem, and pick the profile, but when i start cutting, i can cut every other slab, not all of them.
I tried creating a generic model (not a void) using the same method, it didnt work too
without an explanation ...
is there any fix? or a work around??
