There is a very nice option in spot elevations, Display Elevation. Giving the elevation on top, bottom or both.
But why o why is this an instance? Please make this TYPE.
Gelöst! Gehe zur Lösung
Gelöst von rxi.gg. Gehe zur Lösung
I suggest you to share this in de Ideas forum:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Feels like this should be posted on the Ideas page...
Revit Ideas - Autodesk Community
What's the time-savings of choosing a TYPE over choosing an Option? I think it would be six of one; half-dozen of another.
BTW: the Options Bar sets the Default for subsequent Markers placed. Options can also be used to change multiple selections in one fell swoop - similar to picking a replacement Family from the Properties Palette Preview Selector.
1 - Place 30 spot elevations, Change to top and bottom, move the spot elevations so they are readable.
2 - Place the spot evelation directly in the right spot.
What would be more efficient?
And it is Dutch, not German. ![]()
