Glass railing with clamps
5 REPLIES 5
1338 Views, 5 Replies
Hello everyone. I am really new in Revit so i need help!. I am modeling a straight staircase with a glass railing and 4 clamps on each glass panel. I could fix panels but I can't fix the clamps! They appear even outside the glass panel. I drew the clamp on the family of glass panels and there, they look good, but when i up load them on the project appear off the axis ... I'm sure I'm missing something if someone can help me, I'll be very grateful!. I attach an image to explain it better. Thanks!!
5 REPLIES 5
Doesn't sound like they are constrained properly. Post the family.  Lets check it out.
in reply to: barthbradley
Thank you!. I'm really new to this, so I'm sure I made a lot of mistakes...
I really appreciate your help!!
P.S.: I hope to be exporting the family well, if you can't load it please let me know
A little more work than I thought.  Check out the rebuilt.
Notice that the Clamp is now a nested family. Also notice the parameters I added. I grouped them under "Model Properties".
Important to understand here is Work Planes. Most all of the elements I placed are hosted to Ref. Line Work Planes -- some of which are hosted to other Ref. Line Work Planes.  The family would not flex properly otherwise.
Drill down from here to learn more about Work Planes:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Thank a lot!!
Yes, i will review your link bellow, i need to study more to understand how families work, because it is confusing for me. Sorry for the extra job you did!! and again thank you very much!
Thank a lot!!
