Glass railing with clamps
5 REPLIES 5
1255 Views, 5 Replies
Hello everyone. I am really new in Revit so i need help!. I am modeling a straight staircase with a glass railing and 4 clamps on each glass panel. I could fix panels but I can't fix the clamps! They appear even outside the glass panel. I drew the clamp on the family of glass panels and there, they look good, but when i up load them on the project appear off the axis ... I'm sure I'm missing something if someone can help me, I'll be very grateful!. I attach an image to explain it better. Thanks!!
5 REPLIES 5
Doesn't sound like they are constrained properly. Post the family.  Lets check it out.
in reply to: barthbradley
Thank you!. I'm really new to this, so I'm sure I made a lot of mistakes...
I really appreciate your help!!
P.S.: I hope to be exporting the family well, if you can't load it please let me know
A little more work than I thought.  Check out the rebuilt.
Notice that the Clamp is now a nested family. Also notice the parameters I added. I grouped them under "Model Properties".
Important to understand here is Work Planes. Most all of the elements I placed are hosted to Ref. Line Work Planes -- some of which are hosted to other Ref. Line Work Planes.  The family would not flex properly otherwise.
Drill down from here to learn more about Work Planes:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Thank a lot!!
Yes, i will review your link bellow, i need to study more to understand how families work, because it is confusing for me. Sorry for the extra job you did!! and again thank you very much!
Forma Design Contest
