Getting switches and outlets to display in RCP
vanderloo5
Message 1 of 26
vanderloo5
I have a feeling this question has been asked a hundred times but I can't seem to find the answer. After seeing differences of opinion on doing electrical, (residential), plans in a floor plan view vs. RCP, I have, at least for the time being, managed to get the setup and display I want in an RCP view. Except now I need to find out how to get switches and outlets to display along with ceiling fixtures.
Thank You
Replies (25)
Message 2 of 26
L.Maas
Depending on how you have your project/view setup. It might be a matter of modifying the view range or making use of the underlay function. Depending on the family categories and visibility setting of the families you might need to make changes to the families and/or visbility graphics overrides.
If you need a better answer for you particular project you would to upload (a relvant part of) your project so we can have a look at what you have sofar.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 26
There's always the old invisible model line trick...
https://revitoped.blogspot.com/2008/01/aaaahthe-old-invisible-line-trick-eh-99.html
Message 4 of 26
RSomppi
RCPs are for ceiling items. The practice of showing ceiling grids on floor plans has made a mess out of people's conceptions of what RCPs are for.
Message 5 of 26
vanderloo5
Well, maybe RSomppi but in my 40+ years as a contractor, every electrical plan I've ever seen has ceiling fixtures and wall outlets on the same view.
Message 6 of 26
RSomppi
I don't doubt that at all. You did say plan, not RCP. It is common practice to show ceiling grids on floor plans. That's where the misconception comes in.
Message 7 of 26
vanderloo5
@barthbradley- Ya there's always that but I would think/hope there would be a simple easy way. I have too many outlet and switch types to go that route. I'm not an architect, but as I mentioned in my reply to @Anonymous, residential electrical plans have ALWAYS shown light fixtures and switches on the same sheet. I guess maybe I should go back to doing my electrical plans in a floor plan view.
Message 8 of 26
RSomppi
Yes and other trades do it too but they are floor plans. RCPs are for ceiling items (only). It is "acceptable" to show ceiling grids on floor plans. In RCPs, hidden lines and breaks in ducts and pipes get reversed and cause confucion.
Message 9 of 26
Electrical Plans in Floor Plans?  How's that working out for you?
Anyways, this is primarily a View Range thing.  The Cut Plane in RCP is coincident to the Bottom Plane. All the other distances are "looking up" from the Cut Plane.
Message 10 of 26
RSomppi
It's common practice in the trade. It works quite well. Especially when accompanied by proper RCPs for coordination.
Message 11 of 26
I'm not following what point you're making. I've been Architectural Planning for nearly 30 years and my planning always included an Electrical Plan (e.g. where switches and outlets are placed and what they operate).
FWIW @vanderloo5
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-5D8831F6-6F15-4BF3-ACEB-06FBC14A5491
Message 12 of 26
RSomppi
I've been doing MEP for about the same amount of time and we only used RCPs for coordination of ceiling items.
Message 13 of 26
curtisridenour
I think if you adjust your view range, your RCP should work fine. We do all of our Electrical Lighting RCPs with lights/switches showing. In the past we also used the invisible line in the switch family trick as stated by @barthbradley to ensure that the switch was CUT in the RCP.
What version of Revit are you using? The orientation of nested annotations changed in like 2022 or something like that.
Are your switches Face Based?
Message 14 of 26
@vanderloo5 : Do you switch your View Discipline to Electrical?  See link I posted above.
Message 15 of 26
Ah! I think I understand your point now.  You don't do your Electrical Planning in Revit RCP Views.  That's fine. Whatever floats your boat. But there is no hard and fast "BIM" rule against it. I mean, you don't get red-lines/comments about the "View" you created the Electrical Plan in. Right?
BTW: In 30 years of planning, only about a third of that time has been in Revit.  ACAD and Hand-Drafting proceeded that.  No "Views" to consider. 😉
Message 16 of 26
RSomppi
That's correct. What I'm talking about is drafting 101. A practice that has been lost through the years.
Message 17 of 26
Drafting 101?   What does that mean?  What's been lost?
Message 18 of 26
RSomppi
"101" denotes an introductory course at college or university in the subject specified.
What's been lost?
Drafting practices that are taught in those classes. Probably, because no one takes or cares about them any more.
Message 19 of 26
What's been lost?
Oops. You lost me again, but sorry to hear that no one in your orbit cares.  That certainly doesn't describe the people in my orbit.    With that said, how does this relate to the subject at hand?  "Getting switches and outlets to display in RCP".
Message 20 of 26
RSomppi
I'm sorry that you can't grasp this. It seems that you may not understand the drafting practices of RCPs. What I am saying actually eliminates the need for the question because those items are not a part of a traditional RCP.
