Getting "Improper Boolean" Error
TravisClemons
TravisClemons
Im trying to have the "Vertical Strut Control" toggle the Yes/No based of its length.
David_W_Koch
@TravisClemons
Revit formulas do not work the way you have it written.  Formulas control the value of the parameter to which they are assigned.
I have not tested this, but believe something like this should do what you want, assuming that when Vertical Strut Type Control is less than 9'-0" you want Vertical P1000 to be checked and Vertical P1001 to be unchecked and the opposite if the value is 9'-0" or greater.
Formula for Vertical P1000:  Vertical Strut Type Control < 9' 0"
Formula for Vertical P1001:  not(Vertical Strut Type Control < 9' 0")
An alternate formula for Vertical P1001 could be:  not(Vertical P1000)
Delete the formula for the Vertical Strut Type Control parameter.
If you want some other result, describe what it is.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Edit: Answered. Nevermind
Enter formula for the two y/n parameters:
Vertical p1000: Vertical Strut Type Control < 9'
Vertical p1001: not (Vertical p1000)
For what it's worth to you, here's the formulas to push yes/no value directly:
