Furniture on 1st floor is showing on ground floor
How do I stop this wardrobe component on 1st floor from showing on ground floor?
syman2000
Depends on how the family is created. Few ways you can try is set the view range and set the bottom and view depth to Level 2.
A couple suggestions:
- Lower the view range Top of the ground floor.
- Change the family category from Generic to Furniture.
RDAOU
@Anonymous
Check the view range...make sure the top range limit / offset doesn't exceed the level above
