Revit 2023 for MacOS
10 ANTWORTEN 10
Nachricht 1 von 11
andreaymonod
12861 Aufrufe, 10 Antworten
With the release of the new MacBook Pro with M1 Pro and M1 Max CPUs, Apple has revolutionised the computer industry (once again), putting Intel and Nvidia (in my opinion) in a much more difficult position. The performance of the new MacBook Pro is impressive if compared to Windows PCs with dedicated graphics cards. I hope 2022 will be the year of revolution at Autodesk as well, it's time to make Revit for Mac. Hope to see Revit 2023 for MacOS!!!
10 ANTWORTEN 10
Nachricht 2 von 11
RobDraw
als Antwort auf: andreaymonod
You should write a blog about that instead of posting it to a user help forum.
Good luck!
Rob
Nachricht 3 von 11
BernardJGarrett
You could use Parallels  or VMFusion with the ARM version of windows.
this work with the M1 and M1 Pro CPU's. And use Unified Memory whatever that is?
In my day it was called Random Access Memory. Still not clear what has been unified.
Nachricht 4 von 11
nope not going to happen
Nachricht 5 von 11
RDAOU
@andreaymonod
Heard rumors in 2030 Vision  :grinsendes,_blinzelndes_Gesicht:
Nachricht 6 von 11
HVAC-Novice
Does the "Mute" function of the forum actually work? After muting these posts still show up in my feed.  For other forums there is a "block" function and it literally doesn't show the posts of blocked person.
Is there a way to actually hide those posts?
Revit version: R2025.4
Nachricht 7 von 11
syman2000
Work around solution exist. So don't discount them if you want shinny to work because you fall for Apple propaganda trap. I remember the hype iPod had when I was finishing school. You have no idea how stuck up some of these people are buying into apple trap while they have no idea there are alternative ways to play the music without trap into their ecosystem. For longest time Apple have made a cult out of people and many don't even know it.
https://www.youtube.com/watch?v=xGT85DY03xg
Nachricht 8 von 11
As I understand, the unified memory is a new kind of RAM developed specifically for the M1 chips. It seems to be plugged directly to the chip, making read/write operations faster. There's a 16 Gb limit, though, apparently inherent to the chip's arquitecture. Apple's claim is that this kind of system can outperform an equivalent PC with more RAM. I have not seen independant tests yet, so I can't assure that.
Greetings!
Hernan.
Nachricht 9 von 11
Yien_Chao
Revit 2023 is already out.
Request for mac os version is pending since 2009.
Nachricht 10 von 11
RobDraw
als Antwort auf: Yien_Chao
Your request belongs in Product Feedback and/or the IDEAS forums. Those kinds of things usually don't go anywhere from here.
BTW, just because it's requested, doesn't mean it will be implemented.
Rob
Nachricht 11 von 11
khodges2
You don't need an especially fast machine for this. Any modern computer will run it. It's a matter of if they see it profitable to port it over to MAC OS.
