foundation
4 REPLIES 4
399 Views, 4 Replies
foundation
Have a slab foundation when I added wall footers they were attatched to exterior walls and on same level as slab. How do I detach from wall and lower from slab?
4 REPLIES 4
Alfredo_Medina
It would be good to have an image to understand this better. In the meantime, try changing base or top offset values.
Alfredo Medina
info@planta1.com
monetlilies-
you need to lower your wall- those are wall footers..
Hi Everyone,
I have a question. I have wall and wall foundation laid out. But now for some detail I need to elevate the wall by 2" without moving the foundation from its level. Is that possible? I am attaching an image.
As seen in the image, the walls bottom and the foundation top are attached to each other. Now I need to move the bottom of the wall without moving the top of foundation. Every time I offset the wall, the foundation moves with it.
Thanks for the help in advance,
Scar
Hi Everyone,
Scar
