How can I set up a formula for when one of my project parameters equals ´TEST 1´ it will change another project parameter to read ´TEST 2´
or is this possible..
Regards
Aidan
Solved by ToanDN. Go to Solution.
I have two shared parameters that I have made project Parameters
Theses are text parameters in identity data of generic Model elements I made
For example, When Work Profile = FOCUSED, I want Work Profile Symbol = (the symbol)
Create them as type parameters and assign the values for each family types.
I only have one type of family, they each look the same.. this is a screenshot of what I am trying to do manually..
Why can't you create different types and each has its own graphic and description?
Seems to me you could get there with Global Parameters.
Dunno. Just spitballing here. 😉
