Footing stops at wall join.....
6 REPLIES 6
frankSRFZD
349 Views, 6 Replies
I have one foundation wall that every time I add a footing to it, it stops the footing from the adjoining wall to stop and not continue to wall end. I have tried removing and re-adding all the walls, I have verified the heights and sizes of the walls and the footing, I have tried disconnecting and reconnecting the wall, and I have also tried to adjust the wall join, but nothing seems to change it.
Any ideas?
6 REPLIES 6
in reply to: frankSRFZD
I don't understand what you're showing or describing, but it almost sounds like a Phasing issue. Why don't you post the file and let us have a look and see.
frankSRFZD
in reply to: ToanDN
I try to select mutiple walls for the footer placement but it still does the same thing.
frankSRFZD
Here is the file....I finally stripped out enough families to get the file size to post.
Reset Wall Profile.
frankSRFZD
Thank you. I didn't even see that the curb cut was in the wrong wall.
Forma Design Contest
Technology Administrators
