How to join two roofs
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
advandes
3740 Aufrufe, 11 Antworten
I'm using Revit 2023
See attached. Can anyone help me understand how to join these two roofs together? I tried using a model in place Void, but I couldn't get that to work and joining them would most likely look correct. Thanks!
AAG
Advance Design
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: advandes
How should it look? Got a picture of what you're envisioning?
...maybe something along these lines?
Nachricht 3 von 12
advandes
Yes, exactly...
AAG
Advance Design
Nachricht 4 von 12
Use Join Geometry.  No need to use any void here.
Nachricht 5 von 12
@advandes wrote:
Yes, exactly...
Join 2 roofs that abut each other. Bada Bing!
Nachricht 6 von 12
advandes
als Antwort auf: barthbradley
One thing.. The shed roof needs to overlap the gable roof with a 6" eave..
AAG
Advance Design
Nachricht 7 von 12
Well then, drop the plate height of the lower roof (or vice versa).  They aren't joined obviously.
Nachricht 8 von 12
advandes
als Antwort auf: ToanDN
Thanks! I don't think I have ever used that command before... It worked perfectly..
AAG
Advance Design
Nachricht 9 von 12
What the heck was the solution here?  I feel like I just got punked.
If the roofs are at different plate heights, there is no join to make.
Maybe I wandered into the Twilight Zone by mistake.  Which way to the Revit Forum?
Nachricht 10 von 12
advandes
I think you misinterpreted the look of the joined roofs. The front slopes are on the same plane. See attached. Simply using the Join Geometry as suggested did the trick, but thank you for helping!!!
AAG
Advance Design
Nachricht 11 von 12
advandes
My mistake. I meant to say there is a 6" overlap on the back half of the shed roof over the gable roof... The first attachment I posted I thought showed that clearly, but I can understand how that could have been confusing.
AAG
Advance Design
Nachricht 12 von 12
So, when you replied to me "Yes, exactly..." and I responded back "Join 2 roofs that abut each other", that was right?
Whatever.
Which way to the Revit Forum again?  :zwinkerndes_Gesicht:
