Hello, I'm an Argentinian Architect working for a construction company. The design department is in Argentina and at the moment we are building an industrial farm in Paraguay, a neighbor country.
Our current design-to-construction workflow consists on building the model in Revit, printing the blueprints in PDF and loading the pdf files on google drive, where the people in the construction download them.
This has many problems, like having to repeat this process every time we update the blueprints, and the mess of having multiple versions.
I would like to know what are the real life workflows that you use to communicate with the construction site.
I know there's a360 bim and 360 docs, the problem with them is that you can't print the sheet as pdf or any other format, you can only visualize them, and we need to print them in the construction site. You could download the model on site and print the sheets, but that would be the same as loading the model on google drive and having someone on construction downloading the model and printing the sheets.
I can't seem to find an answer to the problem, any explanation of real life workflows is really appreciated,
Thank You, Francisco.
