Can you install a PDF printer in Revit 2019?
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
10815 Aufrufe, 6 Antworten
Dear Revit experts, i have a question for you!
To improve my workflow i would like to install a PDF printer that has some oversized Pages, but i ran into an issue.
I could not find a way to implement my .pc3 file into Revit, Adobe PDF is crashing and a browser applikation isn't a smart solution for me.
Dose someone of you had the same issue and perhaps a solution? Thanks for sharing!
Paul Rutschmann
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
not the same Problem, I use cutepdfWriter. so fare no problems for me. so maybe a option to have a look at!
Nachricht 3 von 7
Can you please indicate what build number are you running (see the about dialog)? Is it 20180216_1515?
Nachricht 4 von 7
Paul Rutschmann
pc3 drivers are created in AutoCAD and only applicable in AutoCAD.  If you need to create custom sized page sizes that are not available with your PDF printer, do it via the PDF printer settings.  Below is an example for BluebeamPDF but they all share the same procedure.
Nachricht 5 von 7
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community! I see that you are a new visitor and thanks for posting on the forum. Smiley (fröhlich)
Related information on PDF printing in Revit:
Printing Workflow Diagram
(click on links in the workflow for more information)
For other PDF printers, See article: Revit: PDF export/print options
See Docuflow
A few questions for you, so that I can troubleshoot further:
  • You've mentioned Adobe PDF crashes on your machine- do you receive any of these errors? If so, this could mean that it's a windows issue too.
  • Have you tried updating your Adobe PDF's driver to the latest version from the manufacturer's website?
  • Does the crash occur with a specific project of sheet size?
  • Is this specific to a user/ machine?
  • Do you have other applications open when you are trying to print to PDF?
  • Did the crash occur with any other Revit version?
Looking forward to your reply update.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Nachricht 6 von 7
Viveka_CD
als Antwort auf: ToanDN
Hi @Anonymous
It's been a while and I just wanted to follow up here, any progress on this issue?
Did you seek more assistance on this issue? If this is something you want to explore, let me know, and I can point you towards a few tutorials to get you started and answer any questions you have!
I look forward to your reply update! Smiley (fröhlich)
Nachricht 7 von 7
Viveka_CD
Hi @Anonymous
I have not heard back from you in a while.
Let me know if you need additional information. You are welcome to unmark the solution and continue the conversation if you'd prefer.
