Floor Plans Orientation
9 REPLIES 9
Message 1 of 10
tstewart
2329 Views, 9 Replies
tstewart
Once I started the Site plan, all of the Floor Plans aligned w/ the Site Plan orientation (True/Project North). How do I straighten out the Floor Plans and keep the Site Plan's orientation?
9 REPLIES 9
Message 2 of 10
RDAOU
in reply to: tstewart
RDAOU
By rotating the crop region or by applying a scope box
Message 3 of 10
If what you show is the True North orientation then use True North for site plan and Project North for building plans.  Use different view templates for Site plan and building plans.  You need to rotate True North if you has not done it already.
Message 4 of 10
tstewart
tstewart
The Crop region is grayed out, so I can't rotate it.
Message 5 of 10
tstewart
in reply to: ToanDN
tstewart
Floor plans' Grid lines & Dimensions did not rotate and the "Orientation" tab is greyed out under Properties. Help!
Message 6 of 10
RDAOU
RDAOU
It got confusing what your are trying to do.... isnt it the reply you marked as solution? Project nprth true north?
Message 7 of 10
Check the View template for Orientation.  Your site plans and floor plans should have different view templates.  Site plan's view template has Orientation = True North, floor plan's view template has Orientation = Project North.
Message 8 of 10
tstewart
in reply to: RDAOU
tstewart
The attached plan is aligned to the Site Plan and I need to have it rotated to match the sheet (top is North).
TS
TS
Message 9 of 10
RDAOU
RDAOU
@tstewart
Like this? Can do this also using a scope box as mentioned in previous reply
  • Activate view on sheet (on open the relevant plan view)
  • Make crop region visible
  • Rotate the crop region
  • Make it invisible again
  • Deactivate view
@tstewart
  • Deactivate view
Message 10 of 10
mlaudon
mlaudon
Community Visitor
Community Visitor
I have a similar issue. I am trying to plot my floor plan to a pdf format so I can create an office map with Floor Plan Mapper. I am actually using DWG TruView2023 and my floor plan keeps getting cropped. Is there a way to fit the floor plan to an 11x17 paper size?
Thanks in advance,
M
Thanks in advance,
M
