Hello everyone
is it possible to join two different, ovelapping floors? The desired outcome is for the structural (1) layers to join and form sort of a beam (red rectangle image 2).
Solved by RDAOU. Go to Solution.
Seems like you are looking for Join Geometry
Otherwise, if it is a beam you need over there,
You either need to overlap them or add a beam or slab edge as per 2nd GIF above. The extra connecting element will not come out of nothing (walls extend to join but floor don't)
Here is a GIF using your file (Isn't this what you are after?)
Yes I noticed...Mainly that happens due to the Layer Functions Hierarchy and were the layers are placed with respect to the Core (inside/Above/Below)...Join goes by Layer Function / By Material...However in some cases with too many intersecting functions/layers, the above automatic join may not give you the desired Join. That is when you resort to other means...Examples similar to your case:
