Floor Join
dm0144
Floor Join
dm0144
Hello everyone
is it possible to join two different, ovelapping floors? The desired outcome is for the structural (1) layers to join and form sort of a beam (red rectangle image 2).
Replies (7)
RDAOU
@dm0144
Seems like you are looking for Join Geometry
Otherwise, if it is a beam you need over there,
  • Either add a beam
  • Or add a Slab Edge
dm0144
@RDAOU Yes, I am using Join Geometry tool but I don't get the desired outcome. When joined, both structural layers touch each other and not overlap as in your example. I attache the ex. project. See section.
RDAOU
@dm0144
You either need to overlap them or add a beam or slab edge as per 2nd GIF above. The extra connecting element will not come out of nothing (walls extend to join but floor don't)
RDAOU
@dm0144
Here is a GIF using your file (Isn't this what you are after?)
dm0144
@RDAOU The floor edge will do the job.
I am still curious why the desired join is not achived when both slabs overlap for the desired width of ''d''?
Did you notice the overlap?
RDAOU
@dm0144
Yes I noticed...Mainly that happens due to the Layer Functions Hierarchy and were the layers are placed with respect to the Core (inside/Above/Below)...Join goes by Layer Function / By Material...However in some cases with too many intersecting functions/layers, the above automatic join may not give you the desired Join. That is when you resort to other means...Examples similar to your case:
  1. Beams
  2. Slab Edge
  3. Or converting the floors to parts and using Split/Exclude/Merge and Shape Handles...similar to the image below reproduced from your model using parts
dm0144
@RDAOU Thanks! I will go with slab edge since creating floor parts is not possible in group mode.
