Flipable item
Flipable item
yes_and_no
Flipable item
yes_and_no
My flip board look ok on model, thanks to Toan, see pix.
For insanity shake, I would like to add a rotation control parameter, but ran out of wit.
My parameter always ran into errors...
Can anyone help ? R17 fam attached
Host the component that is supposed to rotate to a Ref. Line Workplane.  Draw the RL in Elevation View - originating from the intersection of  x,y Ref. Planes. Align and Lock tip of RL at this intersection.  Pull your angle dimension from this RL.
yes_and_no
Before I get into doing per yr advise, one Q: the xyRL is at floor level, while the flip board rotation point starts at 36" above floor. How wd I deal with this ?
make the x,y intersection 36" above the Floor then. You can even associate the x RP offset from level distance to a parameter if you want.  BTW, just to be clear: you draw the Ref Lines and Planes in Elevation - not Plan.
yes_and_no
Thx. I got the rotation to work. What a revit achievement for myself.
However, the depth parameter (d) won't work.
I just don't know why...see pix.
Lock d parameter.  If the cabinet height is fixed then change d from instance to type parameter.
Lock the Depth Parameter.  See if that resolves.
