Fascia color does not show up in elevation
roedigerF6NSW
roedigerF6NSW
Hi all, I painted a fascia dark gray in a 3D view but the color will not show up in elevation. I've attached pictures of the 3D view where the fascia is dark gray and the elevation view where it remains white.  You also may notice that all the fascia in the project is defaulting to a beige-ish color based on the roof type properties. Why is this not represented in elevation? Thanks
post the file so we can see what's going on.
I think you're cut plane is to close. Pull it back.
Set the elevation view to Shaded or Consistent or Realistic visual style.
