Hi All, I'm working on some cabinet elevations and would like to show wood grain direction in the pattern. I have a model pattern associated with my material. Everytime I tab to select a handle for the pattern to rotate and subsequently try 90degrees rotation, the command appears to select the whole cabinet for rotation and gives me an error. Is there something I should be adjusting in my cabinet family? What am I missing? Thanks much!
I gave that a go and duplicated + rotated my material image under the Appearance tab, but the model pattern didn't rotate with it. I'm not sure how to go and edit the model pattern file...but maybe that's where I should head next?
