Fix the basics problems
Message 1 of 9
1.) ALL windows MUST be expandable.
2.) Default settings for ALL tools should be customizable. Ie., insane that copy is set to single by default- only multiple makes truly intelligent choice.
3.) Default text tye (ie., Architecture type or Ariel or whatever ought to be SET  the last tool used rule is horrible in this case as well as inconsistently applied across various tools. We always use one font for notes (most frequently) occasions do call for a deviation ie., say site plan parcel names/ numbers might want to go to 1/16” boxed Ariel to distinguish from central blueprint font of 3/32” (or whatever) but having to obey last tool used rule here is just lazy programming and a pain to have to go over and adjust in palette.
4. There are many many more but u get the idea. . .
5.) All laugh at Rob McDraw who is a nasty wanker 🤣👉
Seriously, revit is splendid but the essential interface is often clumsy and the new improvements (while certainly appreciated , are ignoring these annoying inconsistencies- sometimes last tool used is appropriate & useful often it is dumb & cumbersome. . . make an electric plan; when drawing dashed electrical connection lines the bloody tool keeps returning to straight line segment when OBVIOUSLY one wants the end point arc line tool needs to be the default (or let us assign a shortcut for arc!
Replies (8)
Message 2 of 9
RobDraw
If you have a personal problem with me, these forums are not a place to play kindergarten games.
Also, these forums are not for requests for new features or improvements.
Take your thoughts and you immaturity elsewhere.
BTW, a little basic training might be able to get you over the beginners hump and address some of your rookie issues. Then again, you might not be old enough to understand that there is an entire other world outside of your parent's basement.
Rob
Message 3 of 9
RobDraw
You should have a look at your posts. Every one of them is complaints with a smattering of insults directed at the people trying to help you understand that you can't get what you want by complaining about fixes for stuff that isn't broken. Have a look into PEBCAK. Until you can understand that is the real problem, you will continue to be frustrated.
Rob
Message 4 of 9
FWIW: #5 was inappropriate.  I don't understand why you felt it necessary to include it. But that aside, I would be happy to engage with you on #1 through #4.  Let's start with #1. What do you mean by "ALL windows MUST be expandable"?
BTW: You do realize that this is a USERS Forum; right?   I mean; we're not an empowered class.  We're just lowly customers like you are.
Message 5 of 9
Re#5 : He does deserve it as he has always been rude to me . He is often making snide comments.
my comment refers to the simple act of making any menu box fully expandable. . . I would & will post screenshots but currently my iMac 🖥 is being brought up to latest OS X in a repair shop.
when I open the objects box I have to expand all the cells. Annoying but not particularly important. There is another one that opens to about a 4”x 3” H box which forces a scroll to get to bottom when it could fill the height of my 27” monitor. . . others as well.
I gather there are plugins to enable nesting in the palette for various items but who can afford full revit? It would be nice to have that modern feature in LT.
But I will add suggestions to that place when I get the machine back!
Really appreciate your goodwill! 🙏🏾
Mahalo
Message 6 of 9
RobDraw
Did big bad Robby hurt your feelings?
There's a more appropriate place for those, too. It's upstairs at your parents kitchen table.
If I'm so rude, what do you call the stuff that you're spewing all over this forum? Cotton candy?
Rob
Message 7 of 9
Ah there is the lil Robbie . . . rude as is your essence -
You have been challenged to show ur **** or go back to ur gen x cave . . . I’ve been doing 3D starting with the superb Form•Z since 2992 - I wonder is ur genitalia had dropped by then lil Robbie?
So here is my work >>
https://www.houzz.com/projects/users/roland_hoyle
I would love to see your contributions to Architecture. If u are as good as u think u are then u will post  your work. . . ( and if u are a good form maker I will give u a nod - u will always be a wanker 🤣. . .
but you are right, this is tiresome and boring to the others, so let’s take it off line rh?
[email protected]
Message 8 of 9
RobDraw
You're reminding me of my baby sister's idiotic rantings. Self centered and full of errors and false assumptions.
Rob
Message 9 of 9
