Lineweight defined in Title Block family doesn't appear in model file
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
davimelop
1429 Aufrufe, 11 Antworten
Hei guys.
I'm creating a new Title Block Family, but the lineweights defined inside Title Block Family doesn't work on the model file. I already checked the Line Style Settings and Lineweight Settings in both files (rfa and rvt) and they are the same.
I attached the files in case if you wantto see them.
On left is rvt file and on right is rfa
Beschriftungen (3)
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: davimelop
In project, VG > Annotation tab > Titleblock > expand to see
subcategories. That is where you should look at, not Project line styles.
Nachricht 3 von 12
GustavoUbriaco
Hi, you Family it's ok, is the linweight configuration in your project, check this.
Gustavo Ubriaco Contreras
Nachricht 4 von 12
davimelop
als Antwort auf: ToanDN
Thank you for your help, but on VG there aren't any changes on this category
Nachricht 5 von 12
davimelop
als Antwort auf: GustavoUbriaco
Thak you for your help.
It is weird, because on my PC, my project it's defined with 1.2, equal I defined on family
Project
Family:
Nachricht 6 von 12
GustavoUbriaco
So strange, is your revit updated?
Nachricht 7 von 12
davimelop
I'm using REVIT 2020
Nachricht 8 von 12
GustavoUbriaco
 I got it check this all in your project OBJECT STYLES is in 1
Nachricht 9 von 12
davimelop
I'm so gratefull for this.
Inside Object Styles on VG. Sometime I forget it. rsrsrsrs
Nachricht 10 von 12
Hooray for @GustavoUbriaco!  Even with all these merit badges, I couldn't figure it out.
I'm going for the Autodesk Certified Professional Merit Badge next.  Wish me luck. :zwinkerndes_Gesicht:
Nachricht 11 von 12
GustavoUbriaco
als Antwort auf: barthbradley
Let's collect all them buddy, you're a master with or without badges :1.-Platz-Medaille:
Nachricht 12 von 12
GustavoUbriaco
Com muito gosto amigo!
