fix all dimensions of the entire project
mohiroal
Message 1 of 40
mohiroal
Hello
I have two projects when I tried to merge them by inserting the link I find one of them has very small dimensions I discovered a problem with the dimensions   (should be the small is 9million m2 area and the big is in small)
Replies (39)
Message 2 of 40
Is the link brought in at the correct scale/units?
BTW: RVT Link Dims are only visible if you set the Link to "By Linked View" in the Parent View. Is that what you are doing?
Message 3 of 40
Are they CAD files? Choose correct Units when link them in.
Message 4 of 40
mohiroal
Isn't the correct units iam chosen 1st project when started default metric and 2nd project imperial metric now the first one is wrong
Message 5 of 40
mohiroal
Message 6 of 40
Huh? I don't understand the question/workflow. Can you elaborate?
Also, tell us: Is it a CAD or RVT link?
Message 7 of 40
mohiroal
both are Revit. if you seen the screenshot u will see 2 projects the big one should be in small .
Message 8 of 40
mohiroal
Message 9 of 40
Post the RVTs here and we'll look to see what's going on.
Message 10 of 40
mohiroal
"9km" is 3*3 km
Message 11 of 40
@mohiroal wrote:
"9km" is 3*3 km
Nothing is wrong with this model.  Where is the tiny thing that is supposed to be 9 million sqm that you spoke of?  You need to share it as well.
Message 12 of 40
mohiroal
file "point" should be here in "9km" . when insert a file  be like fiqure2
Message 13 of 40
mohiroal
I am trying to merge both but "9km" is wrong dimensions
Message 14 of 40
Is it 921 meter dimension correct or wrong?
Message 15 of 40
mohiroal
all dimensions in this file are correct
Message 16 of 40
mohiroal
problem in in "9km'
Message 17 of 40
Then why don't you send the "9 km" one. There is nothing in this file that remotely 9 km.  If it is a link/DWG/image then you need to send it separately.
Message 18 of 40
mohiroal
oh sorry
Message 19 of 40
When link the DWGs in, choose Import Units = meter.
Message 20 of 40
I don't see an issue right off the bat.
Can you point me in the right direction?
