finishes on arch
finishes on arch
finishes on arch
hi ,
how can i apply plaster with paint finishes on highlighted areas(arch and horizontal face), pls help anyone have idea for this.12345666.jpg
Ilic.Andrej
I suggest creating an in-place family with sweeps. Create a sweep and pick 3d edges.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
MostafaElashmawy
You can use paint tool.
Mostafa Elashmawy
Edit Profile of Wall which has the Finish Material Layers.
How did you apply the Finish elsewhere?  As a Wall Layer? If so, then edit the shape of that Wall.
if i use this how can i take thickness of finishes
If you need volume of plaster, add a calculated parameter to the material take off schedule and use the formula Material Area * the thickness you want the material to be.
