Light missing from render
31 ANTWORTEN 31
GELÖST
Nachricht 1 von 32
3820 Aufrufe, 31 Antworten
Is there any trick to fixing a light (brought in from bim object) that isn't sowing in the render?
I tried 2 different recessed and neither show. But the pendants I put in do show.
31 ANTWORTEN 31
Nachricht 2 von 32
als Antwort auf: Anonymous
Do the Lighting Families actually contain a Light Sources. Open the Families and verify.  You can Post the Families here if you like. Or, post the Project containing them.
...you could verify existence of Light Source in Project by going to 3D View that has the Fixtures and turn on "Light Source" Subcategory under "Lighting Fixtures" in VG Overrides.  This will make the Light Source Geometry visible in the View.
Nachricht 3 von 32
als Antwort auf: barthbradley
I can try to figure out how to find the actual family to post
Nachricht 4 von 32
They seem to..
Oh but when I turn on light source in the 3D view I don't see anything
Nachricht 5 von 32
Use "Attachment"  to post a RVT or RFA. But, judging from these screenshots, I don't think Light Source is your problem. What are your Rendering Settings? Also, verify that the Light Fixtures aren't buried inside solid Geometry .
Nachricht 6 von 32
Check to make sure no geometry in the Family itself is positioned in front of the Light Source and blocking it.  Check the Materials your Family is using in the Project.
Nachricht 7 von 32
I believe this is one of them...
Nachricht 8 von 32
Jack up the "Exposure Value". That help?
Nachricht 9 von 32
In the light source or the render settings?
Nachricht 10 von 32
Render the Scene and then adjust exposure settings
Nachricht 11 von 32
So I did that and hit render, its been on 0% for 10 mins now. Is that normal? Thought revit renderings were supposed to be fairly quick?
Nachricht 12 von 32
I think something is off..
Nachricht 13 von 32
Sounds hardware related. Not Software. Took me approximately 15 seconds to Render what I posted above -- and I used "Medium".
Here's another Rendering showing how the "Ring" geometry looks with a Self-Illumination.
Nachricht 14 von 32
Yeah, something is off --- the Materials.  Assign a Project Material to all the Family's Material Parameters that I showed above.
Nachricht 15 von 32
As far as I can see, none of the Materials listed in the Error are Light Fixture Materials. You know, I'm starting to doubt whether any of what we've been talking about has anything to do with your issue.  Post the Revit File.
Nachricht 16 von 32
I was getting renders last night, they were dark but still. And it was quick. Now nothing I'm not sure what changed. I have the final due wednesday I am starting to really worry.
Nachricht 17 von 32
Start from scratch then. Recreate the Views.  Sometimes Views get corrupt inexplicably.
Nachricht 18 von 32
Doesn't seem to let me upload my file, even in zipped folder
Nachricht 19 von 32
I changed the ring type but it is not showing, at least this view rendered and is not black like the other. I would like to have it how you showed when you changed the ring type..can't even really see them in the ceiling.
Nachricht 20 von 32
