Please see image
I have a rule for the double doors to be all in magenta.. like the single door in the image however it doesnt show in the model
Here is my rule cut patterns
What do i need to do so that they show orange? thanks
Solved by TripleM-Dev.net. Go to Solution.
Its catching the frames, so the filter is working. Are the door swings shared families in the double doors? I'm not sure if that'd make a difference but its the first thing I'd check.
Hi @AidanHawkins,
In addition to @mhiserZFHXS comment, the swing + double doors could be annotation lines in the family and placed in the projection type category?
What happens if you also override the Projection Line?
If so the families are build differently.
Else post the file.
- Michel
