Our office has four different elevations that use: building, demolition, interior, and cabinetry. I would like to have elevation tags for each type and then be able to filter those depending on the plan. For example:
I also want this to be as user friendly as possible for the office. So far, I have duplicated the Elevation tag family and created the four different types. I selected the tag - edit type - duplicate - rename (- applied the corresponding view template). Then I went to filter and created a new filter, ex. Cabinetry Elevations, selected Elevations for the Category, and Filter Rules: Family and Type, Does Not Equal, Cabinetry. Hit 'Ok', then unchecked the Visibility check box. All four elevation types on my screen disappear!!! I have tried different rules, like 'Contains' and 'Equals', all with the same outcome. What is going on?
I do know that I can create a Project Parameter, I named it Elevation Type (instance family), and selected each elevation tag individually assigning a name to it, and can then I can filter the tags successfully. I just want it to be more automated. I hoped that the Project Parameter could be by Type, and not by Instance, but the Views Category option disappeared from the list when I tried....
Please help!
Solved by JasonKunkel. Go to Solution.
This process can definitely work. Not sure where you are hitting a snag, but there is no reason to create a parameter to control this.
A guess might be, are you typing in "Cabinetry" in the filter rule value, or are you using the dropdown to select the precise name? In the image below, I clicked the dropdown and selected a value instead of trying to type it in, and my test worked great.
If you are already doing this, take a screenshot of your filter rules and post so we can take a look.
- Floor plan - we want to see the building elevations and interior elevations
- Cabinetry plan - we only want to see the cabinetry elevations
- Demolition plan - we only want to see the demolition elevations
Please help!
It works here. Are you sure the actual Elevations placed in the view are set to different Types?
I was typing in Cabinetry and not selecting the type by dropping down the menu! I knew it was something little. Thank you so much!
