Filter Selection Keeps Annotations On
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Working in 2015 and 2017.1.1 and noticed that when I attempt to select elevations family through a filter that they do not always go off. Want to only select ones that begin with A, AL, ID, etc so I can turn them off for various disciplines after duplicating views. We have Architecture (A) and Architectural Lighting (AL) which we duplicate a lot of similar views. Instead of manually hiding the elevation family for the discipline we do not want to see, I would like to select it via a filter and then only turn off the AL or A depending on what sheet I am on. If I add a filter and select the family for elevations and turn off their visibility with no other filter selections, then all the elevation families go off. Once I introduce a secondary selection, then only the elevation view goes off leaving the elevation family on. Any recommendations to get the whole elevation tag to go away so that I do not manually hide each one?
in the attached image, the ones that are grayed out should be off completely, but only the view goes off.
