Filled Region Area Parameter
MOPAC24
Message 1 of 12
MOPAC24
Please can you make the 'Area' dimension reported by the filled region be a parameter that can be scheduled?
I know there are work arounds using shared parameters + dynamo, but that is very clunky.
This would be a very good feature to have!
Thank you!
Replies (11)
Message 2 of 12
vitorbortoncello
Use Color Schemes
https://www.youtube.com/watch?v=6bn1yxmaq3c
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Message 3 of 12
I'm not following. Filled Regions are Annotations. Are you wanting to schedule Annotations?  If so, for what purpose?  The answer to that question will help us to help you. 😉
Message 4 of 12
MOPAC24
Essentially I just want to be able to pull the filled region area data out and display it in a table or schedule on a drawing that will automatically change if the filled region is changed.
Does that make sense?
Message 5 of 12
What do the Fill Regions represent?
Message 6 of 12
MOPAC24
Site coverage calcs...gross site, net site, building coverage, landscaping area...other various areas that we need to show to comply with planning regulations.
Message 7 of 12
Why not use Areas or Property Lines?
..heck, you could use Rooms or Spaces or Zones for that matter.  Areas, Rooms, Spaces and Zones could be assigned Color Schemes, as @vitorbortoncello mentioned, if you want to jazz up your planning with some color.
Message 8 of 12
Use Area plans and area tags / schedules.  You can create different Area Schemes for different purposes so that are independent from each others.  Area color schemes are a plus.
Message 9 of 12
MOPAC24
Hmmm yeh I could I guess.
I'll have a play and see.
But I still don't know why Revit doesn't let you pull the area data from filled regions!
Message 10 of 12
MOPAC24
Thanks everyone for the suggestions.
Still a wish list to have filled region areas be a data you can use though!
Message 11 of 12
ESA-elaine
Community Visitor
Community Visitor
I am using filled regions to calculate the ventilation areas on the facades which should be a quick exercise if its possible to schedule the areas of a specific filled region
Message 12 of 12
fkerkhof
Every time you generate an area plan Revit chooses colors.
Why can't I use predefined colors (like I can in filled regions, which I can define in the template)
For Every project I have to manually change the colors and when only one thing changes I have to change them again! Really stupid!
