Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Filled Region Area Parameter
10 REPLIES 10
Message 1 of 11
MOPAC24
528 Views, 10 Replies
Please can you make the 'Area' dimension reported by the filled region be a parameter that can be scheduled?
I know there are work arounds using shared parameters + dynamo, but that is very clunky.
This would be a very good feature to have!
Thank you!
Labels (2)
10 REPLIES 10
Message 2 of 11
vitorbortoncello
in reply to: MOPAC24
Message 3 of 11
I'm not following. Filled Regions are Annotations. Are you wanting to schedule Annotations?  If so, for what purpose?  The answer to that question will help us to help you. 😉
Message 4 of 11
MOPAC24
in reply to: barthbradley
Essentially I just want to be able to pull the filled region area data out and display it in a table or schedule on a drawing that will automatically change if the filled region is changed.
Does that make sense?
Message 5 of 11
What do the Fill Regions represent?
Message 6 of 11
MOPAC24
Site coverage calcs...gross site, net site, building coverage, landscaping area...other various areas that we need to show to comply with planning regulations.
Message 7 of 11
Why not use Areas or Property Lines?
..heck, you could use Rooms or Spaces or Zones for that matter.  Areas, Rooms, Spaces and Zones could be assigned Color Schemes, as @vitorbortoncello mentioned, if you want to jazz up your planning with some color.
Message 8 of 11
Use Area plans and area tags / schedules.  You can create different Area Schemes for different purposes so that are independent from each others.  Area color schemes are a plus.
Message 9 of 11
MOPAC24
Hmmm yeh I could I guess.
I'll have a play and see.
But I still don't know why Revit doesn't let you pull the area data from filled regions!
Message 10 of 11
MOPAC24
Thanks everyone for the suggestions.
Still a wish list to have filled region areas be a data you can use though!
Message 11 of 11
ESA-elaine
I am using filled regions to calculate the ventilation areas on the facades which should be a quick exercise if its possible to schedule the areas of a specific filled region
