Where does revit store its 'guesses' when entering parameter values?
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
MichaelWolff
285 Aufrufe, 3 Antworten
Whenever you enter alphanumerical data into a parameter Revit proposes auto-fill options based on entries you made to the same parameter at another point in time.
I wonder whether there is a way to list all of these options other than generating a schedule and filter for unique values. Is there some .txt or .json file hidden somewhere? Perhaps the auto-fill values are generated on the fly?
Tags (1)
Beschriftungen (1)
3 ANTWORTEN 3
Nachricht 2 von 4
vitorbortoncello
als Antwort auf: MichaelWolff
Revit does not store these suggestions in an easily accessible or permanent file like a .txt or .json file. there is no direct file or setting within Revit to access or modify the auto-fill behavior, and it is generated dynamically based on existing data.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 4
Create a Key Schedule which has all the values listed in Data Rows and Export Schedule to CSV.
How to export schedule data from Revit to Excel (autodesk.com)
...and/or load into another Project via Insert from File.
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-36EDBF1E-4EF1-4584-BA24-D66E6F398ABE&p=RVTLT
Nachricht 4 von 4
handjonathan
Hi @MichaelWolff
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @vitorbortoncello @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
