Hello Revit Community,
I’m currently working on creating a Revit family for an adjustable chamber made from HDPE pipe.
The design includes a concrete biscuit for both the top (which will have an opening) and bottom which both will be made separate to this family. My goal is to create a flexible family that allows the user to adjust the chamber’s height and diameter while maintaining the integrity of the design. May have to consider the pipes internal dia and internal dia as this may vary as the pipe size increases.
Here’s what I’m aiming to achieve:
• Adjustable Height: The chamber’s height should be easily adjustable within the family.
• Adjustable Diameter: The diameter of the HDPE pipe should also be adjustable.
• Material Assignment: The HDPE pipe and concrete biscuits should have their respective materials assigned for proper visualization and scheduling.
It may be also good to consider how I can ensure that the concrete biscuits adjust correctly when the pipe chamber dimensions are modified?
Any tips, best practices, or examples would be greatly appreciated!
Thanks in advance for your help!
Best regards,
Luke.
Sounds like a job for connectors.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-92B74F31-03EB-4D14-93A1-BD4E4294A629
Thanks a lot for posting your question to the forums! Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
