Files not appearing when inserting families
IMCornish
Message 1 of 10
IMCornish
I am trying to insert a family in a project but the family is not appearing in the dialog when I use the 'Insert from File' command and drill down to the folder that contains the family I need.  If I use File Explorer it and many others, that do not appear in the Revit dialog, are all there!
Anyone got any ideas why this might be happening?
Andrew Robertson
Chartered Architect
Robertson Partnership
Truro. UK
Replies (9)
Message 2 of 10
"Load Family" to load an rfa. "Insert from File" to insert rvt.
Message 3 of 10
Sahay_R
To make sure that the family has loaded, scroll toward the bottom of your Project Browser and look for Families. Expand Families. Once you find the family, then expand it and drag the 'child' into your project. Simple and painless.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 4 of 10
IMCornish
Sorry my stupidity, I meant 'Load Family' sorry...
Andrew Robertson
Chartered Architect
Truro. UK
Message 5 of 10
Sahay_R
The above responses still hold good!
Rina Sahay
Message 6 of 10
IMCornish
It isn't going to be there if you cannot pick it in the first place.... Perhaps you had not seen my response to the first reply?
Andrew Robertson
Chartered Architect
Truro. UK
Message 7 of 10
IMCornish
I don't see that at all....
Andrew Robertson
Chartered Architect
Truro. UK
Message 8 of 10
Do you see the RFA fie extension when you look at them via Windows File Explorer?  How about drag the file from File Explorer and drop it on you Revit window?
Message 9 of 10
Sahay_R
Can you share your file?
Rina Sahay
Message 10 of 10
Viveka_CD
Hi @IMCornish
We wanted to check back in with you on this post. How is everything working out?
Please let us know if further assistance is needed from the community on this post.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you.
